Starter Problem
firekirin
hope you can help i dont know what the problem is unless i m wrong... here is the situation i have an s13 blacktop in an s13.. i m havin a stater problem... when i first put the engine in and everything hooked up. i tryied to start it but it make a cliking noise.. the starter seems to be trying to engage into the flywheel but it doesnt line up right i guess and it disengages.. well so i thought it was the starter... so i went and bought a starter for a 93 sentra se-r. just took the nose cone off the sentra starter and put the sr20det one onto the new starter which i believe this is ok right? well so i put it on and the same thing happened ...i can get the engine to start but i have to keep turning the key off and on untill the firing sequence is right and the engine starts.. so i figured the problem was the flywheel so i just bought a spec flywheel from heavythrottle.com this past week... put the flywheel and everything back into the car and the same thing happens... it seems like the starter isnt engaging the right way now i dont know what to do and there is no one local in my town that can help me cause they dont know what the hell engine this is and so i figured i would asked on the forums.... right now this is what i have on the car if anything might help
sr20det blacktop 3in greddy dpgreddy fmicspec stage 2 clutch and flywheelapexi avcr but boost is at stock 7psioil filter relocation kit
that is it everything is basically stock i m really stumped if you can help in any way i would greatly appreciated
yellow_jacket
Car: 95 240sx
Is the motor turning over at all? Or is it just clicking? If you are having problems with it actually not having the power to turn the motor over you need to start checking your battery, grounds and positive batt. cable.
sr20det
Car: Drifting, draging, silvia projects
when i first swap my redtop to my car i start and than later on it clicks too so what i did is put a ground wire on starter to wall and the starter never clicks again. try that.
