ven »
https://forums.nicoclub.com/ven-u142928.html
Fri Sep 11, 2009 8:02 am
My wifes 97 D21 KA24e engine threw a rod a few months back since then I got what I was told to be a 91 KA24e out of a pickup. I swapped over all the 97 componnets to the new block, Now here is problem. I am trying to track down a Starter for the truck by finding out the 97 starter we had will not fit due to the block I got has a bump out at the bell housing which is interfering with the solenoid location of the starter. I was told that this motor came out of a 91 pickup, however the castings on the side of block say Japan and the origional motor that threw the rod is stamped Mexico. From the research Ive found the Japan cast blocks came out of 240sx and the Mexico cast blocks were primarily D21 motors. So I am unsure if this IS indeed a truck motor.
I have 2 questions:1. what years 240 KA24E starters are the same?2. Is there any way to find out the engine year from the casting numbers? here are the numbers if so... KA24 038784W
