PublicMenaceINaZX »
https://forums.nicoclub.com/publicmenaceinazx-u67063.html
Sat Jun 02, 2007 11:48 am
Hey guys new to here,
I just finished swapping out the auto transmission in my 92, i went to start it and the starter just kept spinning. I took the starter off to see if it was bad, but its fine. I then decided to measure the distance the gear traveled and it should hit the fly wheel. The only problem i'm having is that the fly wheel teeth are sitting at the tip 5/8 in, the starter only goes in 1/2 to the tip of the gear in. I never took the fly off the motor so i dont see how it could have moved. The starter does not even touch it. Any thoughts? Thanks guys.
