90TSIAWD »
https://forums.nicoclub.com/90tsiawd-u53743.html
Fri Jun 05, 2009 8:45 am
Alright, so I have the VH on the engine stand and want to do a compression test while it's out of the car. I've done this with lots of other motors and never had an issue. This particular motor though when I hook up the jumper cables and push button starter switch (the ones for testing, I'm sure you've all seen them) the starter spins but does not push out to engauge the flex plate... any ideas? I tried jumping the pins on the inhibitor (probably park/neutral safety switch) and still no dice.
Current setup, ground jumper cable to bellhousingstarter positive battery lead on positive bat terminalstarter switch jumping terminals on solenoid when button is pressed
Thanks in advance, Rob
