Starter Not Kickin? - KA24DE Swap
Pro ViZion
Car: 1990 Nissan 240SX w/ KA24DE
Hi everyone.
Ok so I just got my twin cam motor installed and all the wiring finished but my car doesn't want to crank.I checked the voltage at the solenoid wire on the harness and it reads like 11.2 volts.
I also swapped starters as well already.
Anybody know what may be happening?
Thanks in advance.
Patarach
Car: 240sx convertible KA-T
Is your block grounded?
Is it a AT or MT ecu/harness
If it is check EL-12
B/Y wire
Pro ViZion
Yeah its a manual transmission.
Car is a '90 with a 93 motor and wiring harness. ECU says "EL" on it.
And what do you mean by block grounded? If you mean the motor then yes it is.
nofatchicks0073
Car: 91 hicas RIP
92 hatch RIP
89 hatch parts
90 hatch in the works
he means you need to ground the engine when you pulled your single cam out you should have noticed some wires than went from the engine block to the frame you need to look in your service manual to find out where they are its been awhile since i did my last pull if you cant find the locations on the internets via google machine or something i have a service manual i can maybe look it up for you and try to scan a copy of there locations or something later if i get a chance but you need to have it grounded for sure
Pro ViZion
Yeah if your talking about grounds for battery I have it setup from battery negative to chassis then from that point to the intake manifold.
nofatchicks0073
Car: 91 hicas RIP
92 hatch RIP
89 hatch parts
you need to have it grounded in more than one place though do a little rresearch and you will find what your looking for i promise
Patarach
You can either check continuity between starter housing/block and your negative terminal. Or check to see if you have 12v on the block cranking, which would mean its not grounded.
If all is ok there check your clutch switch and relay.
Pro ViZion
So your implieing that the starter might not be getting a good ground?
I was thinking about the clutch switch as well. Do you know where the relay is located?
nofatchicks0073
Car: 91 hicas RIP
92 hatch RIP
89 hatch parts
ok im sorry to be honest i didnt read the whole post i kinda skimmed through it and when i saw that you didnt know what the guy ment about your engine being grounded ii just assumed that was your problem but it sounds like you took care of that so your best bet is probably gonna be either your relay or the clutch your relay is located under the hood in your relay box its a black plastic box that you can pull the lid off of and i belive under the lid there should be a diagram tellin you witch relay's do what if you find that its not your problem than its your clutch witch is a pain in the a** to get to i had a switch go out for my brake light at the brake pedal it self and i ended up getting arressted twice before i spent what seemed like hours upside down trying to get to it soooooooo (fingers crossed) i hope thats not your issue if none of this works you can always climb under the car with a screw driver and cross the psitive and negative on your starter and makes sure it works that way just triple check thaat the car is in neutral so you dont run yourself over hope this helps let me know if you get it figured out or not
