Infinitiguy19 »
https://forums.nicoclub.com/infinitiguy19-u84424.html
Sun May 23, 2010 6:35 pm
I understand what your saying and many do refer to electricity as water in a pipe. But I spoke with many car audio/alarm shops before I under took this project and most said to use a bigger smaller ground wire if I can. There reasoning was that the wires i need to run to the sensors, solenoids and control units can "Only be so large". It needs to handle the electrical load while still being small so 14 AWG seemed the safest since the biggest fuse for the system is 10 AMP's and the wires handle 15 AMP, its logical to think the fuse will blow before the wire heats up. And as seen from my posts about the power window fuse (25 AMP) blowing, that was my main concern.
Some say to use the same gauge others say to use a bigger gauge ground. As long its the same size or bigger it doesn't matter right?
What could happen with a bigger ground VS power wires?
Again the power wires are 14 AWG and the ground is 10 AWG.
