starter missing in a horrible way help plz
s1390
Car: 1990 240sx Silvia front end conversion ca18det swap gt2876R
i have a sr clutch and flywheel in my ca and my starter was missing in a horrible way so i did some research and found a write up on which starter to use so i went and got a gear reduction starter (the hoodless one) from a 1986 Nissan 200sx but its still missing not sure what to do about it except pick up a ca clutch and flywheel ideas much appreciated
float_6969
What do you mean missing?
boost_boy
s1390 wrote:i have a sr clutch and flywheel in my ca and my starter was missing in a horrible way so i did some research and found a write up on which starter to use so i went and got a gear reduction starter (the hoodless one) from a 1986 Nissan 200sx but its still missing not sure what to do about it except pick up a ca clutch and flywheel ideas much appreciated
Picking-up the appropriate parts might be your best bet because you're losing money and gaining gray hairs with the amount of labor and frustration that goes with experimenting.
s1390
when you turn it over it grinds so i swapped the starter with the gear reduction starter (the hoodless one) from a 1986 Nissan 200sx and its still grinding im thinking that the first starter may have damaged the flywheel but heres the link for the write up where i got the info from
http://www.driftopia.com/2007/06/21/ins ... e-ca18det/
boost_boy
s1390 wrote:when you turn it over it grinds so i swapped the starter with the gear reduction starter (the hoodless one) from a 1986 Nissan 200sx and its still grinding im thinking that the first starter may have damaged the flywheel but heres the link for the write up where i got the info from
Dude, the aftermarket has more than enough support for CA clutches and virtually whatever you need. Screw the SR's clutch crap and get a CA clutch set-up because you are in for a big loss in labor backed-up by mad amounts of frustration, only to realize that you really gained nothing by using or trying to use SR components on a CA18DET.
