Mikoriad »
https://forums.nicoclub.com/mikoriad-u21033.html
Mon May 02, 2005 3:42 pm
I just had a similar prob. My starter began making that horrible, gear grinding noise from time to time. In a couple days of hearing that the first time, it gave out. Turns out the part of the starter that covers most of the gear broke off. I hit the junk yard and got a used start of an old 240. It's a pain to reach the two bolts holding it on at first, but once you figure how to twist and contort your arms it's a cake walk. Paid 14 dollars for a used started from a junkyard. For you info, you can use the starter off any 240, 89-98, sohc, dohc, doesn't matter. I say goto the junkyard pull one first, to get an idea of how to get it out, and then replace your bad one. For me (first time replacement) it took a total of about 45 mins to remove and install, that 14 dollars was all I paid. I think you can also use the starter off the first gen altimas.
