Starter issues
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
After getting everything tidied up a bit I ran into a problem. The starter does not want to fully engage the ring gear and thus makes an awful grinding noise.
I am using Wes's adapter plate. Has anybody else run into this problem. I'm not sure how to remedy the situation other than replacing (or spacing) the ring gear further aft on the flywheel (balance issues?)
Let me know.
SuperHatch
Car: 96 TLC
LEMHEAD16 wrote:After getting everything tidied up a bit I ran into a problem. The starter does not want to fully engage the ring gear and thus makes an awful grinding noise.
Let me know.
Are you using the Z starter or the Q starter?
Carl H
you'll have to use a spacer of sorts to make up the difference in plate thickness that spaces the trans out.
gs14racer
The starter issue is what superhatch said your probably using the wrong one, but the flywheel has to be shimmed anyway to take up space on the plate so make sure you did that otherwise youll have clutch problems.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
gs14racer wrote:The starter issue is what superhatch said your probably using the wrong one, but the flywheel has to be shimmed anyway to take up space on the plate so make sure you did that otherwise you'll have clutch problems.
Using the Z starter.
GS I'm not sure I understand your post. I used the factory Q flex plate spacer between the engine and flywheel. Wes's adapter is only 1/4 inch plate steel. are you saying there needs to be more clearance between flywheel and crank?
gs14racer
Yes i believe you have to stack TWO flexplate spacers between the flywheel and the crank. The spacers are 1/8 iirc. Looks like transmission drop is in your future.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
DOH!!!
Are the flywheel bolts long enough to support that?
Anyone have an extra flywheel spacer?
Carl H
if you use arp bolts they should be more than long enough.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
ive actually got a part number for some fastenal bolts you can use..
I only used one spacer and I got pretty good engagement.
whats your flywheel/transmission combo?
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Z32 flywheel and starter. Both are from NA models
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
I've got one of Wes's plates too and the starter placement appeared to be OK with the flywheel with only one spacer.
Maybe you could slot the holes in the starter to move it forward a bit to suit. Does the clutch disengagement appear to be right?
And Wes, what is the part number for the ARP bolts that you used, wouldn't mind getting some.
elwesso
2007 BMW M Coupe
I actually used factory bolts with one spacer, still got good engagement...
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
I used the stock bolts too. Although ARP might have been cheaper. I think I paid about 8.50 a piece from Nissan.
I am looking into slotting the bolt holes to move the starter forward. That is the Idea that I have been thinking about since I realized there was a problem.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Fixed. Just an alignment issue I guess. I had to grind a little bit off the adapter plate and it started up fine.
Thanks
Carl H
glad to hear it got sorted...factory bolts were too rich for my taste and even having to buy two sets of arp ones was still much cheaper than oem.now get to work finishing up the exhaust and all that jazz and go pwn.
elwesso
2007 BMW M Coupe
where'd you modify it?
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
basically i just notched it where the nose of the starter hit it.
Return to “VH45DE / VK45DE / VK56DE Forum”
