BurnsAuto90 »
https://forums.nicoclub.com/burnsauto90-u29750.html
Thu Jun 14, 2007 8:15 am
alright heres the problem im having.
had to take out my (sr redtop) transmission because of a shifting problem, fixed it and put it back in. hooked everything back up...go to start the car, and all i hear is the starter solenoid click once, and then nothing. took the starter and the battery to advance auto, had them tested. battery is fine, and the started is decent..but the bearings are startin to go. cleaned up the connections and even replaced the connection for the tab on the solenoid itself. threw is back together, and still the same problem. I recently relocated the battery to the trunk, so i redid the ground and made sure that was good, and checked all the other wiring..but still havent come up with anything.
maybe it could be the ground on the starter itself, being dirty, etc?
any ideas would really be appreciated:)
