elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Thu Sep 17, 2009 8:41 am
OK I cleaned this thread up a little bit..
Anyway, first off to dsagers.. NOt necessarily. I had a relay that would click but would intermittently engage the starter.. I took the relay out and banged on it a few times and it worked great, but I keep a spare on hand. Maybe built up corrosion or something?
Try jumping the starter relay. disconnect it, and with a paper clip or jumper wire go across the switch terminals.. IF that works, then you know you've got a bad starter relay. if that doesnt work, you've probably got a connection issue.
Try that and report back.
