Robi1 »
https://forums.nicoclub.com/robi1-u56059.html
Sun Sep 09, 2007 11:41 pm
Hi, battery is first to check, any auto sparky can test for battery condition, usually for a minimal charge. you said when you had starter off it turned over? second thing to check are your connetions are clean HT at both battery end and where it goes on to starter, fine grit sandpaper usually does the trick also LT wire check the wire terminal itself is clean. some solvent degreaser and blotting paper. also check the conections are tight. dont forget to clean all faces where the starter goes into th bellhousing as it's the main earth to the starter, then check all the HT earthing connections from battery to chassis to motor clean with sandpaper and check for tightness. A very cheap tool I have is a humble anologue twelve volt gauge. run a voltmeter across the battery terminals with motor running if you get 13v or more then alternater is good. If sparky says battery checks fine and problem persists then starter needs new brushes and cleanup, usually alternators wear brushes first, I've only done about 350 alternators compared to 60 starters, another thing to check is the ignition relay usually somewhere on the side of the engine bay or in the fuse compartment. Most starters require 10.5v or more to crank clicking's a sign of weak battery 99% of the time.
