The block isn' the only issue... it's the diameter and number of teeth on the flywheel. Also, it must mate with the bellhousing.Seishuku wrote:Any CA20 or CA18 starter should work, the blocks are the same FWD or RWD.
I'm actually using my old CA20 starter on my SR20... Slightly modified.
Yes it works. Only difference is on the RWD starter, both holes are threaded whereas the FWD only one is threaded. The other one will need a longer bolt with a nut on the back of it. As for install, it's pretty easy. Just disconnect the battery, jack the front up, and remove the pass wheel. Remove two bolts, remove the starter. Simple as that.ceniorstudies wrote:ok so the ca18de fwd starter does work for sure? how hard is installing a starter and can someone explain installation more in depth. thanks in advance.
my bad... just looked at my post and realized i didn't even tell what car i pulled it from.. it was a ''88 pulsar.. and i didnt look to see what model it wasNeedCAforS13 wrote:what? what car did you pull it off of? your post makes no sense without more information.
did it have red valve covers? If so it was either the CA18 or CA16. not sure if they're interchangeable, but I would guess they are. there was also a GA16 that came in the pulsar, but it looks nothing like a CA.ceniorstudies wrote:my bad... just looked at my post and realized i didn't even tell what car i pulled it from.. it was a ''88 pulsar.. and i didnt look to see what model it was
