Starter Inhibitor Relays, location on a 98 Infiniti I30t
TOMCATTERS
Car: 68 PRO STREWET ROADRUNNER ./BLOWN 440
HI ,JUST CHANGED OUT THE STARTER ON MY 98 INFINITY I-30 T, AND WAS TOLD ALSO TO CHANGE OUT THE TWO INHIBITER RELAYS IN THE ENGINE COMPARTMENT , FOUND ONE, THE SMALLER OF THE TWO CAN NOT LOCATE THE LARGER (BLUE)DUEL PLUG RELAYS LOCATION ./ANY HELP WOULD BE GREAT THANK YOU .
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
plz don't abuse the caps lock... there's a box wit about 10 or 12 relays and one is marked anti theft/start. is that the one you're looking for?
btw why replace those? not working?
TOMCATTERS
Sorry about the caps, Im a aviation mech. all my paper work must be in caps , anyway in the box with the starters came a tech notice stating that these relays should be changed .Not doing so can lead to a burned out starter and void the warrenty also said location was on the inner fender ,the one i found was in front of the battery. I looked in all the boxes in the engine compartment and under the dash to ? Thanks
allensteiner
there's one more on the right of the battery which houses relays. i believe it's that one.
