nissanblaze »
https://forums.nicoclub.com/nissanblaze-u23633.html
Sat Jan 28, 2006 10:14 am
I went to start my 240sx the other day it is a 1990 model with a manual swap with a ka24de motor. The car was running poorly before that but not once the start broke and grounded agaisnt the chassis the car will no longer start even though I replaced the starter and the ecu fuse. I have traced wires and can't seem to figure it out. I am not getting fuel or spark. It seems that the ECU was bad and I replaced it. Still nothing. Is there something I am missing? I have replaced a lot of fuses, and relays and cannot seem to find the problem. The car will crank but won't trigger the fuel pump or the coil. They are both getting power but not being triggered. I tested both the pump and the coil and both have tested fine. Any suggestions?
Please Help.
-Curt
