starter grind
kapower240
Car: 1992 300zx
hey guys i just got a red '92 300zx NA with around 230k miles on rebuilt engine and chassis. Everything seems to be normal along with engine except that on two occasions when i tried to start up the car the starter seemed to make a grinding noise instead of the engine cranking and the second time i tried to start it up it turned on like normal. Then on a third occasion it grinded two times then it was normal again. So far it seems to be doing it randomly during these last two weeks that i had the Z. Now my question is will I have to replace the whole starter or just the drive part which i think is grinding becuse its sounds like a gear is grinding but then im not really sure how the starter works. But either way I want to fix this before I end up getting stuck in the middle of nowhere because my car wont start. Thanks guys
91300zx
Car: 1991 Nissan 300zx 2+2
Mine did that too and I found that if I turned the key into the on position and waited until the yellow light went out it will start fine. I think its like a solenoid in a diesel... Just gotta let it sit like that for like 3 seconds.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
it's the throw out selenoid on the starter getting weak, check your battery conections, if everything is good and free of corosion, you might want to swap in a new starter
tg
Have the same problem with my 90 N/A, once out of every 12 starts or so it doesn't engage and just spins... i'm guessing its the solenoid but i'll know for sure when I have the transmission off and can get a good look at it.
