So I have a 98 Maxima, stick shift, just replaced the starter a couple months ago. Sometimes, especially when cold when I go to crank the car to a start, instead of starting I hear a grinding noise out of the starter. Seems like if I stop and try again it will make that noise several times in a row without starting. Before it seemed that if I waited a little bit and tried again it would start up with no noise, but now sometimes after I wait it will make the noise again. Could it be a bad flywheel? is the new starter I put in bad? Anyone's help would be much appreciated.
Modified by Rhinoguy11 at 11:59 AM 10/10/2009
