ghettoslide »
https://forums.nicoclub.com/ghettoslide-u18248.html
Thu Jul 15, 2004 1:03 pm
starters have bushings a quick test that may work is to tap on it with a hammer or wrench, if it starts it's the bushings in the starter, You can rebuild it or replace it. I rebuilt mine with out actually buying new parts, rigged it to work because i needed the car for work and school, i got another week out of it. Replaced it on the weekend, That click you hear when you turn the key is the starter solonoid, it works just the starter motor does'nt, if it is a standard try push starting it or poping the clutch if this works again it is the starter.
