viso wrote:Can you suggest any links or articles that can help me with the lifting and banging part?
Also, am I correct in assuming that the long-term solution is to replace the starter motor? Thanks
Well, by "lift," he meant have the CAR on a hydraulic LIFT. As far as banging, you're going to want to bang the starter lightly. I'm really not sure where it is on a g50 but someone will probably chime in on it.
Yes - if it's semi -faulty, then replace it. What Maxnix suggested was 80% diagnosis and 20% band aid.
