Starter fuse? no idea
Toahk
Car: 97 ....
Installed a SAFC2 yesterday, didn't hook up the airflow signal wire yet. But anyways, everything worked great yesterday, go to start the car today and it wont turn over. Figured ****, must be the starter, tap the starter - nothing. It will push start fine and drive around fine. So did the starter totally crap out with no warning or what? Is there a fuse for the starter, anything I could check?
Modified by Toahk at 2:17 PM 11/20/2004
s13sr20chris
year and model? i will assume you have what we all have. a 240. if its an early car it will have the starter relay that is a known weak link. it is a blue relay that is not in a relay box but rather on the firewall or one of the fenders. it has two connectors under it with two wires each. whack it and see if it works. you may want to go ahead and check for voltage to the starter on the big wire and the little wire(at starter).
