starter for my SR ?
migsk8
Car: 240sx
what car would i need to type in at autozone to get the same starter that the 93 sr20det came with? sentras?
i need an answer asap please and thank you
and yes i looked it up but i just could not find it
schanne
Car: 93 Hatch-Sr20
I'm pretty sure you can't. But you can swap out the housing on a ka starter. Search bro and you'll find your answers. Just don't forget to read
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
I thght sentras SER of the same year came with the same starter?
danielsan
Car: 1991 240sx coupe SE
take yours out and compare it to the sentra se-r starter.
migsk8
Car: 240sx
seems like no one knows for sure?
Hijacker
Car: '92 240sx Convertible
'94 F-150
FWD starters are not the same as RWD starters. The RWD SR starter is a JDM specific part.
However, if you bothered to search in the RWD SR forum, you would have found a few threads that discuss swapping the lower housing of the SR starter and using the internals from a KA starter.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
i used parts from a pathfinder starter and had a electrician clean mine up. works like a charm afterwards.
