monodark wrote:Could the silanoid be done for. Is there a way to fix this problem till I can afford my new starter?
Yes
monodark wrote:But if I touch the positive n the negative on the starter with a screw driver the engine starts to crank.
And you answered your own question...
Other ways to do it:- have a manual car? push start or park down hill wherever you go.- have a buddy? have someone tap on the starter solenoid w/ a long rod - i.e. jack handle or whatever - while you crank the car - I did this for a while when my starter was going out.- If you don't have a buddy, you can still do the method above, but you will need to tap the starter by yourself for a good 30 seconds to 2 minutes depending on how dead it is; this will knock the stuck part loose, then you can start like normal.
Another thing to check is your battery terminals - even if you hook up another battery, but the terminals are bad or not making good contact, then you will have starting issues.
I just fixed my latest starting issues yesterday - car was reading 12v off, starter clicked but no crank, I'm like "oh noes".
Checked the battery again & noticed the positive terminal had slowly gotten loose over time and was barely making contact. Tightened it down & car starts normally again - worth the 30 seconds it takes to check to save yourself from more work.
