starter cranking while car running HELP
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
thought i would re post cause i feel neglected2nd new starter, new starter switch, new starter relay,car starts perfectly ,then usually when pulling or backing out of driveway wheels cut small bump the starter will crank ( producing the hideous gear grinding noise) for 1-2 seconds. my mechanic says there was no visible wires that could be shorting out help help helpj
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Starter solenoid sticking?
We had something like that in the enigne in our boat. We had to hit the solenoid with a mallet to get it to "unstick" itself...
jamesmost
wes this is the 2nd new starter in 2 weeks they both cant be stickingcan there be a short in the line somewhere grounding outalso this did not occur until the new starter went in
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
Try replacing the starter relay. A lot of times (at least on Hondas - I know no comparison), a bad starter can increase the load on the relay and cause it to go bad along with the starter. It's a good idea to replace both (again at least on Hondas) at the same time. Maybe you should give it a shot.
elwesso
2007 BMW M Coupe
He replaced the relay.....
This is kinda weird, gotta besomething thats grounding... Can you get under there and inspect the wires.....?
gniknave
Hmmm...yea maybe some loose wires...then again TWICE???
Q45tech
Are you using oem starters as replacements or national chain junk?
jamesmost
New oem starter, it does have a shorter drive gear, hirh torque, my mechanic who happens to be a personal friend assures me there are no wires grounding out, car is going in tomorrow for new fan blade and some new bearings in idler pulley, he said he would look further into my startee issue. It had not made any foul noises in 1 week then pulling out of a gas station this morning at approx. 30 degree grade heard the ***** scream for a second.
Q451990
By OEM you mean factory? The shorter drive gear and higher torque makes me think that it's new, but not OEM. I think you just found your problem.
The other option is that maybe you're hearing your ilder pulley locking up and mistaking the sound for the starter???
Heath
jamesmost
did not purchase from infinity but brand new from same mfg. i really dont think it is the pully i hear, the noise is the starter cranking while car running i think:)
