crzycav86 »
https://forums.nicoclub.com/crzycav86-u9237.html
Tue Sep 14, 2004 3:52 pm
Try bypassing the solenoid. The starter solenoid is the blue box right next to the battery on the left. You can try probing the wires with pins, and connecting them. It might let the car start.
I had this problem on my car after I did some work on it. I think it has something to do with the alarm system being partially disabled.. or something like that.
If that doesn't work, try bypassing the clutch sensor switch. That's the switch that's engaged when you press in the clutch...
And if none of that works, try connecting the battery directly to the starter, and see if it kicks in(leave the car in neutral, of course). The hot wire for the starter is under the intake manifold. There's a connection there that you can open, and run power directly to the starter.
Anyway, those are some things that may help.
