Starter...best way to pull it off
kevy8up
whats the best way to unbolt the thing from the top or the bottom. OK..im changing my clutch tomorrow. and the last time i had the car up the starter is WAY the hell up there. should i try gettin the back bolt for the starter from top or bottom...just askin.
kevy8up
bump dangit
zombieman
probably bottom because if it's from the top, the heater core hoses will be in the way...i did mines from the top, then again the hoses were remove when i did it.
Japican
Car: s13 (crashed) '03 wrb rex
My dad helped w/ mine, He was underneath and I was ontop, but we did most work underneath. Needed to be ontop to help tighten the nuts while he worked on the bolts.
