starter and plugs???
onearmedbandit
Car: 1990 s13 fastack (reddtop sr20det)
my starter went out on my redtop s13 sr20det, what kind of car should i get a new starter from?.....also if anyone could give me a number for some good spark plugs that would be much appreciated..
slow s13
Car: cars, photo, music
hahhaah there is no usdm equivalent, jdm only on the starter. Some people have said its possible to swap the guts from the ka starter onto the backplate of the sr starter so you basicly just change out the part that conects to the transmission. If you dont feel you could try that I'd get on ebay.
robbbby
There is a whole thread on spark plugs at the top of the second page.
Nismo31
Get the starter at Auto Zone because they have a lifetime warranty. Get NGK plugs n wires for your car. edit: go to http://www.nopi.com for the NGK's
SR20DETPoweredS14
Car: 1999.5 Audi A4 1.8T
Nismo31 wrote:Get the starter at Auto Zone because they have a lifetime warranty. Get NGK plugs n wires for your car. edit: go to http://www.nopi.com for the NGK's
Like SlowS13 Said there is no USDM equivilent considering the 180SX/Silvia was never sent to the United States. You could contact Cardinal Performance to see if they can get you a starter for your SR considering they sell alot of used SR parts and they say that you can ask them to get you a part and they will.
180fan
Car: 89 fastback
or you can contact Marco of sr20parts (i think that's the url) or Ronald at Venus. Those are the two guys I go to normally for my used SR parts.
sparkplugs.com
NGK plug#s for 95-98 2.0L 240SX:
BKR5ES-11 (Copper)BKR5E-11 (V-Power)BKR5EGP (Platinum - don't use if you're running nitrous)BKR5EIX-11 (Iridium)
Some of Denso's products that used to be OE/available at the dealer only have recently been released to the aftermarket. Depending on the year, this starter should be available for under $200.
robbbby
sparkplugs.com wrote:NGK plug#s for 95-98 2.0L 240SX:
I'd get a heat range of 6 for an SR depending on the boost level.
