Started my LS1 swapped 240sx today for the first time v.videos
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
IHeartTurbo
240cp
Car: 95 240sx
Nice
Blown240sx
Car: 1996 240sx
Does no one give a **** about warming the motor up?
IHeartTurbo
Blown240sx wrote:Does no one give a **** about warming the motor up?
yeah, good idea to run the engine up to temp with no coolant in it right? this was just to see if it would start, ****bag.
ScrapMetal
Car: 1999 Chevrolet S10
1991 Ford Bronco 5.0
What motor mounts did you use?
IHeartTurbo
Metaru_Gia wrote:What motor mounts did you use?
I built the mounts, modified the xmember, wired it up, etc. The only thing I didnt do was reprogram the ecu.
hinds90
Car: 89 240 sx
How much did the swap cost.
IHeartTurbo
hinds90 wrote:How much did the swap cost.
a lot in parts. zero in labor.
furple
Car: 1992 Nissan 240SX Fastback
could you provide a number?
hinds90
Car: 89 240 sx
furple wrote:could you provide a number?
LOL same thing I was thinking. I understand if you don't want to give the exact number. What about an estimate.
Is this a track car?
Joe
IHeartTurbo wrote:yeah, good idea to run the engine up to temp with no coolant in it right? this was just to see if it would start, ****bag.
it was definitely a bad idea to rev a cold engine that high. ls1's do not like >3000 rpm when cold. thats how you break valvesprings.
expect $6000+ to do a ls1 swap correctly, doing all your own labor.
Blown240sx
Car: 1996 240sx
For that I hope your motor blows.
If you dont have a radiator on it and its cold start up what gave you the idea to rev it that hard? If youd like I can get some LS1 builders on here to chew you out about what happens.
Well like I said blow the ***** up I could give two ****s since you dont seem too.
Blown240sx
Car: 1996 240sx
It really depends on the upfront motor costs. I could see a 5000 build if you knew exactly what to buy and how to install it.
IHeartTurbo
****, you guys are faggots. Haven't you ever been so excited about something that you do something that shouldn't be done? Yeah I shouldn't have rev'd it like I did, but it doesn't mean you have to be faggots about it. Loosen up.
aceof07
Car: 91 240sx
everyone needs to chill out! but awesome job btw, if you rev'd it while it was cold who cares? its still fine and its your engine. i really want to do this swap one day.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
I'll warm your motor up.
1991ls13
Car: s13 ls1 hatch
where did you get your motor and transmission dude?
Return to “Hybrids”
