Start up problems.
DriftBandit
Car: this is my 3rd 240sx
Ok, I have the S14 sr20det in my car, Its been in 3 different cars, 2 S14's and a S13. Well when I had the motor in the first s14 I would be able to start my car just fine. But when I put the 300zx MAF and SAFCII it started fine, until the next morning when it was cold, I would crank it and it would seem to catch for a split second then turn off. I have to keep cranking it for maybe 5 minutes before it starts. Well I crashed my S14(damn drunk driver running a red light and hitting me) and put this motor into a S13 and it would start fine first time all the time, Then I crashed my S13(damn understeer) and have put this motor into another S14 and the same problem applies as the first S14.??The MAF is grounded to batt and wiring is right, Anybody know what might be happening???Thanks for the help.-Jon
mikesloud
Car: turbos and SPL world champ
mine does same dam thing and in wideband it gets a little lean at idle and has a small sputter like vac or boost leak but it does not have any leaks!!!
ever since z32 mafs and injectors it has had dam problem!!!
hopefully someone can help on situation
DriftBandit
Bump
