Start up help
brunswick240
Car: 93 240sx SE
Alright so ive got everything hooked up all ready to go, but i dont have my safc. Ive got 370s, t25, smic, stock fuel pump, oil feed and return, rfl, and a stock maf. Now im wondering if i can start the car up with out the safc, just to move it and check to make sure everything is hooked up. I have nothing else hooked up for tuning, just waiting for the safc2 to come in.
Chezedik
Car: 1991 Nissan 240sx
You can, but you will likely run rich. Not a big deal, but you may run rich to the point of bogging out the car. I don't think you should use it though without a wideband. You will need to properly tune the injectors, which you can have someone do, or you can do yourself if you have the right tool.
brunswick240
Car: 93 240sx SE
Ive got some safc settings from the guy that sold me the kit, that he had tuned with wideband. If you have some extra time maybe you could help me out with some settings and check out the ones that I have...if you dont mind. That would be very helpful and i would extremely appreciate it. Thanks for the help.
Chezedik
That would probably buy you some time. The injectors w/o it though will still run at the same duty cycle w/ a larger orifice, so your computer will be going crazy trying to adjust fuel.
