agne24us »
https://forums.nicoclub.com/agne24us-u9236.html
Thu Aug 07, 2003 7:46 am
there are a few other posts along this line, but mine seems to be different in a few ways. here is my problem.this problem developed in the past 2 weeks without warning. actually it was the next day after installing a new stright through exhaust, i still cant think of any relation betweent the two. but what happens is the car most of the time will start and rev up to around 1500rpm then stall. after a few more attempts it starts and runs smooth, wether it is cold or hot the engine does this. lately i have replaced the PCV valve, O2 sensor, cleaned the AIV, the one thing i ran into today was trying to adjust my idle down, it stays at 1000, and when it gets lower then that, the system will correct itself and increase the revs. I basically cant get the idle below 1000. I also have tried the air regulator unit, pinching the hose while the engine is running give me no drop at all, I am not sure if there is any way to test the IAA, or the AAC valve, i have a cd rom manual that is completely worthless in all its troubleshooting areas. I am not sure about vaccum leaks since the car runs perfectly at other times and i even hooked up a vaccum gauge and the readings were aroun minus 15.ANY IDEAS WILL BE GREATLY APPRECIATED!!!:help :help
