Start of my 1jz build
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
ngibson
Car: 90 s13
Been here a while, been workin' on my project over the last month or so. Single'd 1jz, r154 transmission, gt40-88 etc.
I've been planning to do a 1j'd s13 for the longest time, I had mount kits, wiring everything sitting here just waiting to buy the engine. But at that point, my buddy got sick of taking this car from shop to shop and getting it screwed up. So I bought it from him, sold my parts and started gettin' dirty.
Still got a long way to go with this, waiting on more parts to arrive. Gonna pull engine, paint bay, gotta get new carpet, install turbo timer, boost controller, etc.
Here's the work I did over the past weekend. Car is a black hatchback
Stripped interior
There were termites everywhere. Scubbing bubbles > termites.
Foamed up dead spaces
Sanded it all down, then wiped it down with lacquer thinner
e-dead v3 sound deadening paint. This stuff has the consistency between JB Weld and cake frosting
Cake's done!
Gauge pod I'm finishing up
Best damn part of the car
Ignore the wiring. I've got another harness that's going in. MTR butchered that harness, along with the turbo and a few other things.
I've got Evo Brembos going on the car, along with some new rims, 180sx body parts, and too much more to list.
My daily / parts donator (once I get my company vehicle):
As of 11/2/08
Gauge pod almost finished, can see a few small imperfections. I'm too much of a perfectionist for my own good.
Here's what my calipers look like so far:
Supplies:
Before:
(I forgot to take pictures of it stripped)After:
Adapter brackets:
Some work to the car, mainly got it ready to pull. Gonna order the engine bay paint soon. Took out the harness, disconnected hoses, took off turbo, downpipe etc
George workin hard
Modified by ngibson at 5:56 AM 11/4/2008
grenade180sx
Car: 180sx
good stuff dude keep this updated frequently
im currently doing the same into my car as well!
ngibson
Car: 90 s13
grenade180sx wrote:good stuff dude keep this updated frequently
Nice, what kind of setup do you have planned?
Got another update for ya:
Got a lot of work done today.
My roommate working on takin' manifold off
Tools
Engine puller / forklift
Here she comes
Dirty damn engine bay
After some scrubbing bubbles - that's me with the hose
Sanded ready to paint. I ended up using epoxy appliance paint. It's reallly tough stuff, ever tried scratching the finish on a refrigerator? I tried chipping some of this paint on a test piece earlier in the day, it takes some force to even scratch it a little.
Here she sits at the end of the day
1991ls13
Car: s13 ls1 hatch
dang, good stuff so far, thanks for your help on my thread,but im thinking if ill be spending pretty much 5k i`m leaning towards the ls1 even though with the 1jz you can just turn up some boost and minor stuff and you got yourself a rocket
ngibson
Car: 90 s13
Update from few weeks ago, never got around to posting the pictures.
Best thing for cleaning engines:
This is what happens when your car sits at ter-tech for a year:
1JZ, bishez.
Junkyard carpet
Here's a quick preview of my gauges
ngibson
Car: 90 s13
Evo rotors showed up, they're huge!
Blitz boost contoller
Injectors came back from Deatschwerks
550cc's
Kalypso
OH MY GOD... well done!
does the 1j have forged internals like the 2J? besodes displacement, whats makes the two motors different?
you're doing great, and I'm learning.
ngibson
Car: 90 s13
Kalypso123 wrote:OH MY GOD... well done!
Thanks for the compliments.
I'm not sure about the forged internals. I'll have to check that out.
Other than displacement, there isn't much difference. A lot of the parts are interchangeable: rod and main bearings, valves, seals, injectors, head gasket, pistons, water pump etc. The heads are completely interchangeable as well.
Here's a good list of 1j / 2j parts FAQshttp://www.supraforums.com/for...92754
Kalypso
thats plenty, thank you.
RCA
ngibson wrote:Update from few weeks ago, never got around to posting the pictures.
Best thing for cleaning engines:Scrubbing bubbles
Ngibson's Gauges
What process did you use when useing the Scrubbing bubbles?Did you just follow the directions on the can or a special technique??
I like the way your gauge pod came out. But no radio?
Also I don't have proof but I have heard the "rumors" about stock JZ forged parts but from what I read on the JZ and Toyota forums those rumors are false.
ngibson
Car: 90 s13
rcabrita wrote: What process did you use when useing the Scrubbing bubbles?Did you just follow the directions on the can or a special technique??
Just spray it on, it usually lifts most everything off but on thicker grease I use an old toothbrush. Then hose it down.
The radio will be mounted in the glove box, I always use my mp3 player in my car. Can't stand regular radio so no real need to see it all the time.
Now I'm going back and forth on rebuilding my gt40, or going with gt28 twins.
RCA
Wow that is easy!
But going twin GT28s is serious money!What is your power goals with this project?
ngibson
Car: 90 s13
rcabrita wrote: Wow that is easy!
For stuff that is caked or burned on, you need a heavier duty degreaser though. I use scrubbing bubbles on engine bays, a lot of the heavier degreasers can fog up clear coats and paints. Depends on the paint though.
But twin gt28's would be so baller, with 500+ rwhp at lowww rpms.
If I get mid 500's I'll be perfectly happy with the setup. I'll probably be on around 18 pounds for daily, 22 when I wanna kick some *** on the high way haha.
ngibson
Car: 90 s13
Got a bunch of work done today.
My dad build this box over our toolbox a few weeks back. Just got this light installed, made a huge difference
Painted the block - semigloss black
This is the best thing you can do for yourself when working on any project, buy a box of ziplocks and a few sharpies.
My diagram for removing headbolts / camshafts
Not too dirty, nothing worse than can be expected from a 10+ year old engine
I had almost **** myself when I saw this
Then I realized it was from me not taping the intake ports off well enough, and was just water from me hosing it down.
Six cylinders bishez!
New headgasket installed
Time for a Dew break
My drawing was less detailed than needed, so I printed out portions of the fsm.
Dropped the oil pan. The lower portion has a bigg dent in it. And I felt the need to reseal it all, and paint bomb it.
ngibson
Car: 90 s13
Painted
New 2jz water pump and thermostat
Here she sits at the end of the day:
ngibson
Car: 90 s13
Update!
Got a bunch of work done today:
ARP Head installed
Less dented oil pan arrived
2jz water pump pulley from OHRLY
When I was removing the head bolts I broke an extension in the tool, after fighting with it to remove the broken piece I just bought another one.
Headstuds in and cams reinstalled
Painted timing cover
Cleaned and painted fuel rail
Installed 2jz injectors
Removed timing gear to install new front main seal
New front seal, painted lower cover, timing belt installed
sandblasted and painted oil cooler tubing
Dirty alternator
All cleaned and installed
Here it is at the end of today
ngibson
Car: 90 s13
Clear timing cover
New cam gears
Installed
Cover reinstalled
Blitz!
Drew out my mounting template
Do work!
Cut out
The mounting hardware
Clamp it up to bend, used a rubber hammer to bend it over nice and flat
This is where it's going to be mounted
I had to bend it some more to get the angle I wanted, here it is bolted in, and this crazy strong double sided tape to hold it on
ngibson
Car: 90 s13
Time for the turbo timer
The material for the mounting bracket
Damnit! I needed to paint all that ****!
Before
After - the button emblems were taped over
0range_Kouki24O
Car: s13 coupe and s14 sr20det w/2.3 stroker
one of my friends is a noob at the 1j's and as for myself i know only a little bit but not much. he cant find any websites that has ARP head bolts for a 1j. question is..if he ordered head bolts for a 2j would it work on a 1j
ngibson
Car: 90 s13
0range_Kouki24O wrote:one of my friends is a noob at the 1j's and as for myself i know only a little bit but not much. he cant find any websites that has ARP head bolts for a 1j. question is..if he ordered head bolts for a 2j would it work on a 1j
They sure will. About 90% of the parts are interchangeable, he can use 2j bearings, rods, pistons, wrist pins, oil pan, waterpump etc. Cams however are not interchangeable.
Look at this thread, you might have to registered to look thoughhttp://www.supraforums.com/for...92754
1jz240sx
who did your wiring for you.
ngibson
Car: 90 s13
1jz240sx wrote:who did your wiring for you.
2jzswap.com. You mail in your ka harnesses and the jz harness. They match em up, connect all the necessary wires and leave the ones tagged that you need to hook up to the chassis. Very clean job, they recover and retape the whole harness too.
ngibson
Car: 90 s13
Got a **** ton of work done today.
The parts donor!
Hooray blown suspension! Fell out when I put it up on jackstands.
Do work son!
Parts parts parts
ngibson
Car: 90 s13
My roommate helpin out
My roommate being... special
That's where I left off today. Tomorrow, I'll be swapping brake lines over. Installing the front suspension, mounting the Evo brakes, installing exhaust and swapping interior over.
jrivera
Keep it up Nate. Surprised there is little interest in this thread. Oh well.
ngibson
Car: 90 s13
Package showed up today
From these guys:
My shifter extension! Been waiting so long for this to come in. Now the engine can go back in.
Speedo interface box. The Tach one is backordered.
ngibson
Car: 90 s13
Got another good days work in. Mounted all my electronics, ran bunch of wiring, and fixed little things like the gauge pod sitting flush.
Removed the uncracked dash
Sparco wheel
Dash reinstalled
Removed these ugly bastards
Plate to mount my TT and Boost controller
Extended the TT wires into the harness
Went and picked these up for power distribution, top for power and bottom for ground.
My roommate came up with a good idea for once
Break time with brown people haha
Me doing some wiring
Messing with some more wires
Final coat of clear on the cluster
You can see us in the gauge
Stock speaker covers installed
Kalypso
looks great... I love everything
the 3 pod gauge setup looks awkward...but its not a big deal.
ngibson
Car: 90 s13
Why do you think it looks awkward, if you don't mind me asking.
I like it, saw one on another s13 at one point - wasn't as nice as mine, but I liked the idea a lot. I was going to put them on the A-pillar but I didn't want to worry about getting them stolen.
ngibson
Car: 90 s13
I didn't do much today, I'm still waiting on a lot of parts to come in.
Installed the shifter extension
Mounted intercooler
The holes for the piping has been bothering the hell out of me, so I fixed it.
Cut cardboard template
The material
Bend it down with a big #$^&ing hammer
Riveted in place. I forgot to take pics of the other side. I also treated that rust, rubber undercoated the bottom and spray painted the top.
Return to “Hybrids”
