ka24e510 »
https://forums.nicoclub.com/ka24e510-u23202.html
Thu Jan 13, 2005 6:26 pm
well, nelson8708's problem is the bearings in the starter, it will make a grinding, shreiking noise after the car starts because the starter now has to stop spinning, the bearings are done. you will have to replace the starter soon.
now for eastcoast chaos, there are only 2 things that contact each other when the motor is trying to start, there is the starter and the flywheel. sometimes when the problem lasts too long, you will end up damaging both peices.
