tinaslynn »
https://forums.nicoclub.com/tinaslynn-u38158.html
Mon May 08, 2006 3:53 am
Ok, I have two questions... Got a 90 Nissan Stanza (m/t, ka24e) undergoing some serious work....
Question #1: Did some searching on p/s pump on the forums.. apparently odd for them to go out... this weekend, I put in a new rack/pinion... after running it, it started making a whining/grinding noise when turning left, coming from pump area... possible air in system? or could my p/s pump have decided to take a dump now that a new rack is installed.. Gonna check belt later since I did take it off and replace the belts as well... seems to turn fine, no jerking, etc.. just grinding like crazy especially on left hard turn... and how hard is it to replace this thing, if it comes to that.. I can't even see the thing... it sits right up against the tire wheel/firewall.
Question #2: Got a grinding noise in front end, right side... This has been going on for a couple of weeks... progressively gotten worse... it is a grinding/rotating sound which seems to be coming from right side.. it is directly proportionate to the rotation of the tire while driving. (this has been hard to check by myself.. gotta find someone who can drive a stick and run it with the front tires off the ground). It progressively gets worse from 15-55 mph and seems to taper off but still evident at higher speeds. Revving/nuetral, etc does not effect it.. it is specific to the rotation of the tire... since being a front wheel drive, manual transmission, I am assuming a possible output shaft bearing.. or perhaps an inner wheel bearing in the spindle that I am not aware of??? can't think of anything else it could be. Does not effect overall driving of car, but does have some shake in front end (had front end alignment done yesterday, but still shimmies a bit, tires could be out of rotation too).
As far as items replaced in conjunction with these issues: new rack/pinion, tie rod ends, brakes, and rotors.
Any tips, tricks, hint would be greatly appreciated... I swear by the time I finish with this car, I will be a Stanza Expert!
Thanks,T
