The speaker bracket ring is actually the speaker itself. The speaker cannot be pulled out of the bracket because it is all one piece. I'm pretty sure the 04's are different from the 07's because mine cannot be replaced. I just lined with dynamat, used self-tapping screws and drilled my own holes. It's as simple as that.mosswalker wrote:Alpine 9887 with a changer in the glove box. plug your iPod into the input built into the unit and you have everything you had from the factory but better. The head unit controls your iPod in case you didnt already know that.
You can make a 6.5 inch sit in that slot pretty easy with no metal cutting using the factory 'ring' the other speaker is a part of. Or build a wooden ring in 5 minutes to raise your 6.5 inch out of the way of the window. Pull the BOSE, your ears will thank you.
You are correct sir ...... its the same as what i pulled out of mine. I never explained myself correctly. Cut the other speaker out and use the ring. Torch and an exacto knife. Heat the knife, cut , heat the knife cut. pain in the ***. Just do the wood rings. A protractor and a jigsaw along with a non alcoholic beverage to keep a steady hand.generic808 wrote:
blancs3030 wrote:when using the metra kit, how do you take off the old center console? I have a d3 on the way and looking to install it maybe by the end of this weekend.
