You don't have to use it but it does prolong the life of the gears in the Limited Slip Differentials. I don't know if the differentials are limited slip in the M35x.But don't quote me on that.sergio1987 wrote:Hey Infinm3506, since you are an Amsoil dealer... Do we need to use the AMSOIL Slip-Lock™ friction modifier additive when using Amsoil 75W-90 Severe Gear® Synthetic Extreme Pressure Lubricant (SVG) in our differentials (AWD specifically)? They say it's for limited slip differentials only, but I can't find any info about m35x differentials
THX buddy, I guess I'll just use the oil without slip-lock, and if i'll get weird noises i'll add it later on.InfinM3506 wrote:You don't have to use it but it does prolong the life of the gears in the Limited Slip Differentials. I don't know if the differentials are limited slip in the M35x.But don't quote me on that.sergio1987 wrote:Hey Infinm3506, since you are an Amsoil dealer... Do we need to use the AMSOIL Slip-Lock™ friction modifier additive when using Amsoil 75W-90 Severe Gear® Synthetic Extreme Pressure Lubricant (SVG) in our differentials (AWD specifically)? They say it's for limited slip differentials only, but I can't find any info about m35x differentials
IlyaKol wrote:I always use Synthetic...so I made the switch to Mobil 1 Full Synthetic... If you do mostly highway and drive easy, you can definitely get 10-15k out of synthetic.
Its not the oil, you need to get an oil catch with a filter and it will stop your burning oil probelmwizard8873 wrote:Synthetic here too. Only issue I've come across, and had this with my Altima, is that not all oils are the same. Amsoil was fantastic in my Altima and got rid of the VQ35 oil burning issue. In the VK45 it hasn't made much of a difference. Need to do an oil change soon and going to try Royal Purple this time to see how it does. So far tried Amsoil, Pennzoil Platinum, and Castrol Edge and Castrol has had the least amount of oil burning in my set up.
InfinM3506 wrote:Its not the oil, you need to get an oil catch with a filter and it will stop your burning oil probelmwizard8873 wrote:Synthetic here too. Only issue I've come across, and had this with my Altima, is that not all oils are the same. Amsoil was fantastic in my Altima and got rid of the VQ35 oil burning issue. In the VK45 it hasn't made much of a difference. Need to do an oil change soon and going to try Royal Purple this time to see how it does. So far tried Amsoil, Pennzoil Platinum, and Castrol Edge and Castrol has had the least amount of oil burning in my set up.
