You can keep all the wiring on your car just the way it is, Atleast until your MAFs is running at max noise. Which means it has hit its max readable amount of air, in which case the ECU will continue to get the last signal the maf was able to read.
So lets say you were running 25 psi through your stock MAFs, for the sake of argument we'll say the max noise of the stock MAF was hit right around 20 psi. That means your engine is ingesting another 5 psi without the ECU being able to add the proper amount of fuel.
This could be a bad thing...Thats the main reason I always say to tune your car on the dyno with a wideband O2 sniffer hooked up.
I ran my MAF at max noise for over a year, but I used alcohol as a fuel additive at anything over 20 psi. So my ECU really didn't care what was going on.
As far as BOV's go, look into the TurboXS unit. You won't find better customer service anywhere on the internet.
http://WWW.TurboXS.com
WD
