Standalone Engine Management For Rb20det
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
IS THERE A STANDALONE FOR THE RB20? POWERFC IS FOR RB25 AND HIGHER RIGHT PLUS IT DOESN'T WORK ON AMERICAN OCTANE. THANKS FOR ANY HELP.
Nathan
PowerFC will work on American gas...you can adjust fuel and timing curves to compensate. Besides, because of the different rating systems our gas is not much worse at all, maybe 2 points less.
PROJECTRB240SX
IS THAT COMPATIBLE WITH RB20 THOUGH?
Nathan
Yeah...so I dont know :) They are made specifically for each application (I'd think there would be an RB20 application) and are loaded with base maps that are the same as what's in the stock computer so they are basically a plug it in and go thing...as long as you dont modify things too much you can plug it in, drive it down to the dyno and then tune it...very cool.
RubHamuSan
fcon pro v....there was one on ebay a few weeks ago i think it went for under 500$. the only reason i didn't get it is who am i going to find to program it i live in the south. not to many hks dealers here.
TropikalSX
Car: Hott girls, 240SX
A really nice stand alone engine management I have seen is: Simple Digital Systems http://www.sdsefi.com They have a really nicely priced setup which you can get with coilpacks etc and it has a hand controller which can be programmed like a power FC but probably a little easier to use. They have done a couple turbo 240SX with good results.
mmdb
Also check AEM they make a programmable standalone, but i'm not sure if they have it for the rb25det or rb20det. I hope so tho... newer technology than the powerfc.
DriFt3r
Car: Racing and Drifting
Are these standalones plug in and go or are the wiring of these pretty hard?
mmdb
i hear they're all plug in with ease for the ease of convenience.
spec-v5150
I havent see a Power FC for the RB20
DriFt3r
Hmmm I am new at this so, what your saying is that these standalone systems will plug right into the engine harnesses of the rb25 right? Is it as easy as that? nothing else to wire up? If so then what would be one of the best units to get for the rb25 motor? Anyone have experiance with this?
Nathan
I didnt think sds was a plug in kinda thing...I thought you needed new sensors
DeltaSteve
Car: putting RB25det in S14a
i've had some bad experiences with an SDS system and a Honda F4-i engine. i don't know if it carries over at all, but i trust AEM
McAdam
Car: I like cars and my motorcycle. boats are fun too
I would look into an E-manage. Its GReddy, so there is tons of support out ther for it (maybe not always the most helpful) and I am sure they would make one for the RB20. Its almost a standalone, but its still a hack. if you get the PC communicator and ignition and injhections harnesses, it can pretty much do anything.
just curious, if you HAVE to type in all caps because of work, how can your subject title be in lower case??
McAdam
spec-v5150
McAdam wrote:I would look into an E-manage. Its GReddy, so there is tons of support out ther for it (maybe not always the most helpful) and I am sure they would make one for the RB20. Its almost a standalone, but its still a hack. if you get the PC communicator and ignition and injhections harnesses, it can pretty much do anything.
McAdam
Bwahahahahahahahahahahaha funny ****
RubHamuSan
also remember using stand alone ,sometimes ac is not a option.also a smooth idle may not be in reach. the fcon comes with a harness for the rb and yo ucan use it with the factory ecu and harness to keep ac and a nice smooth idle.
PROJECTRB240SX
THE BOARD WONT LET AN ALL CAP TITLE, TRY IT. IT AUTOMATICALLY CONVERTS IT TO LOWER CASE AT RANDOM.
PROJECTRB240SX
I HAVE FOUND ONE AT UNIQUE AUTOSPORTS. ITS FOR THE RB20DET SPECIFICALLY, IT ALSO HAS A BUILT IN BOOST CONTROLLER.
