driftfan420 »
https://forums.nicoclub.com/driftfan420-u61259.html
Mon Jan 28, 2008 9:48 pm
How do you determine which is the best standalone? There are so many options out there. -AEM EMS-Apexi Power FC (W/ datalogit) *D-Jetro-Haltech-Motec-Microtech-HKS E-conEmanage Ultimate( Piggy back unless you have harness) AutronicTomei
Ijust need a little help picking one out. I need that has features such as :-knock control-Nos/ Methanol injection control-turbo timer-multiple maps -easily tunable-MAP sensor-Wideband compatible. lamda
I like the power FC, but if you don't have the datalogit, its a pain to tune,-AEM, I've seen the comments about compatibility with the Nissan,SR, RB-Motec, haven't really heard much about.( Which model for S13 SR20det?)-Haltec has some features but not all ( Which model for S13 SR20det?)
I just need a little assistance from someone that's knowledgeable about the subject. I don't want to make the wrong decision and end up kicking myself later. This subject has been covered, I know I know. I"m in a different situation, my engine is already built and running. I'm not in a what if i got this and that scenario, I've already done what i wanted w/ the engine. I don't want something that will start misfiring and breaking up after 500+HP, I need a dependable ECU.
The engine has been completely rebuilt, just breaking it in under the old ECU(mines tune) and injectors(550cc) w/ SAFCII.
TODA SR20DE(T) Intake camshaft 264/10.5mm TODA SR20DE(T) Exhaust camshaft 264/10.5mm Ferrea Dual Valve Spring Kit for Nissan SR20DET Ferrea Valve seats Ferrea Titanium valve retainers Port Flow Manganese-Bronze Valve Guide Set Brian Crower Exhaust +.5 Valves for SR20DET Brian Crower Intake +.5 Valves for SR20DET ER Spec Stainless Rocker Arm Stoppers Cometic 1.1 87mm metal head gasket, Copper Exhaust gasket, Metal Turbo Gasket, ARP Head studsCP Pistons 86.5mm 9:0:1 compression-Eagle Connecting Rods with ARP hardware.Tomei 740cc InjectorsGreddy gt2871R turbo ( Changing out for a full race twinscroll top mount w/ 3076R Turbo)Greddy intake plenium Snow Performance Stage 2 Methanol KitTomei exhaust manifold (heat wrapped)Tomei exhaust elbow
