Stance Coils
nieko
Car: 1989 Nissan 240sx
On the GR + Pro's is there a toruque setting on the top nut? because i unscrewed it very easily when they arrived and put the different springs on but im not sure how much to tighten it? any help would be apreciated.
AceInhole
Stock spec is 43 - 58 ft-lbs.
94_240sx
Car: 94_240SX
AceInhole wrote:Stock spec is 43 - 58 ft-lbs.
Correct. I got the torque spec from Stance and they said it's 55lb
nieko
wow thanks guys
94_240sx
Car: 94_240SX
nieko wrote:wow thanks guys
Make sure to check this thread.zerothread/276053
nieko
one more question you guys. the top nut on the rear coils when i tighten it it basicly just keeps spinning the inside of the dust boot any ideaS?
nieko
bump bump bump pleeaase!!
pat93
If I do understand you and understand what i read from other forums correctly,they use air impact to tight it.
