Odysseus wrote:How long before you wore through those wires Claw? Im thinking of tucking them before I even lower it...
pff... that's probably just from a ride around the block I bet. It doesn't take long before the rubber burns up the lil plastic wrap.
Odysseus wrote:I really want to be as low as I can and I know Ill have terrible negative camber. Im assuming that the front camber plates on the coilovers will correct most of it in the front, but in the rear Ill need RUCAs right?
okay, I skimmed though everyone's reponse, but let me give you the low down on at least the esential parts you'll need/want to get to get a decent ride feel.
1) rear upper control arms (oe adjustments will be maxed out and can no longer be effective)2) rear toe (oe adjustments will be maxed out and can no longer be effective)3) aftermarket outer (and inner) tie rods (lowering your car dramatically will create bump steer, which is NOT good).4 *optional) tension control rods - fix the caster after it has been altered by the lowering.
also, because of the way the front suspension is designed, front camber won't change when lowered (noticeably). Only the rears. As you go lower up front, the tow opens up. I believe its the opposite in the rears.
Second, I wouldn't recommend Megan parts. Its really a hit and miss with their parts. I've heard okay reviews, and I've heard bad reviews (welds coming apart). That's enough to tell me to stray away from their arms.
