E7-S14 wrote:Stance coilovers dont adjust through preload.
the way you did it is a great way to shorten the life of your coilovers.
what you need to do is set them back to 0ish preload. you'll know its 0 when the spring doesn't have much tension on it..
since you lowered it im assuming you didn't add preload. so just adjust it back to the way it was.
to lower correctly. loosen the lower perch, and turn the WHOLE shock body clockwise i believe to lower the coilover.
That is what i attempted to do i had it marked off when i started but from playing with it the marks wore off so i don't know exactly where they were to start but i put them back to where i thought was close and its still to soft. I did not drive on them like that though E7-s14
I'll try and see what Stance say's and if not i will just make it stiffer and lower the correct way from there.
