**Stance Coilovers for AE86 with Spindles!!** **Only AVAILABLE set in the USA**
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
EnjukuBG
Vendor
Car: AE86
Stance-USA only brought in 2 sets of these coilovers for right now, we got our hands on both of them. We sold the first set already, now the last set is up for grabs! More will be available around Feb.
-Front spindle is cast, not machined, cast is 3x stronger than machinedsteel and also much lighter
-Front damper is inverted monotube and featured adjustable camber top plate.
-There is enough adjustment for more than 4deg of camber. Front damper includes extension cable for the adjustment knob, so you don't have to take the damper out.
-Front damper also includes roll center adjuster. Rear setup is OEM spring type.
-Spring rate is 8k front, 6k rear.
MSRP $1895
Feel free to use the images below.
Thank you
Click Here:http://www.enjukuracing.com/st....html
Return to “Advertisers' Marketplace!”
