Stalls when placed in gear
tropicaltan84
Car: 1984 Nissan 720
My 84 720 pick up starts and runs just fine until I put it in gear then it dies immediately. Changed coils, checked vacuum lines, changed torque converter. Any ideas?
Dattebayo
Does it only happen when the engine is cold or at all times?
tropicaltan84
Happens every time. Can rev it up and quickly get to neutral but then it stalls when shifted into drive.
PapaSmurf2k3
Site Admin
Does it jolt the car hard, like the torque converter is already locked up?
Dattebayo
What I meant specifically is what happens after you leave the car in neutral for like 10 minutes as it warms up, and then shift it into gear?
tropicaltan84
Hot or cold it starts, runs, idles, accelerates in park or neutral and stalls when shifted into reverse or drive,
goody90q45
Car: 1992 Infiniti Q45 (sold)
What's the rpm of the engine in neutral at idle, cold and warmed up?
tropicaltan84
No tach but stalls at normal idle or revved up.
PapaSmurf2k3
Site Admin
I'd start with the simple stuff like checking the timing and trying to adjust the carb for optimal fuel/air mixture.
Dattebayo
tropicaltan84 wrote:stalls at normal idle or revved up.
I don't understand what you mean by that. Clarify please?
tropicaltan84
I mean that when I shift from park to reverse or very quickly bypass reverse and shift into park the engine stalls out whether I'm letting it idle normally or giving it more gas. I think something is going wrong in the transmission.
