stalls out when coming o a stop
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
01turbosentra
Car: 2001 nissan sentra sr20det bluebird
ok im new here to the forums i have an 01 nissan sentra with an sr20det bluebird swap if i rev the motor up its idles down and almost stall and when comin to a stop the car almost stall or stalls out completly at times.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Adjust the idle screw out a turn or two. If that doesn't work, report back.
01turbosentra
aight i have codes its p1336 p1401
Modified by 01turbosentra at 4:04 PM 10/19/2006
nametakennow
Car: '06 MINI Cooper S
Neither of those codes show up when I check a list of trouble codes... what ECU are you running? What fuel pump?
01turbosentra
jim wolf reprgrammed 89 240sx ecu
nametakennow
.... Weird, I guess that'd work.
Anyway, the second question: What's your fuel pump situation? Stock or Walbro 255 or what?
01turbosentra
dont know bought the car with motor in it im tryin to get it through inspection so im tryin to clear up the mil
RED_DET
Vendor
2011 Infiniti G37x
I have never heard of anybody using a 240 ecu in a sentra.
nametakennow
Well you'd best find out what exactly you've got. I find the 240 ECU idea rather fishy as well. I guess after JWT messes with things, the ECU can't tell the difference... maybe... sure it wasn't a 200SX ECU?
If your fuel pump is stock, it may be fried. I'm rather certain that's why I'm having nearly the same problem you describe.
01turbosentra
ok i donesnt stall out any more im think those codes are for the iac and throttle position sensor because of its idle characteristics any one no where to fin that part at
nametakennow
01turbosentra
DAMN THIS IS WIERD IM CODEIN FOR AN EGR TEMP SENSOR AND A CRANK SENSOR WTF IS GOIN ON
nametakennow
I don't think the previous owner was completely clear on what had been done to the car.
01turbosentra
i bought it from my moms fiancean he dont have a clue whats done to it
nametakennow
Someone must have a clue.
It's hard to fix problems when you don't know exactly what you're working with.
01turbosentra
yeah it is. im sure i can get the egr temp sensor code deleted with reprogrammin
nametakennow
If you do indeed have a 240 ECU, get a B13 SE-R one tuned by JWT instead and look into the requirements for an OBDI conversion. It should be simple with that ECU, and it'd save you a lot of headaches with trouble codes.
01turbosentra
whats wierd is why can i access my current computer trough obd2 still and why would it throw a code for an egr temp sensor i think its a reprogrammed stock ecu
nametakennow
Stock B15 ECUs can't be reprogrammed, no one's figured out how to crack them.
Is there any piggyback management like an SAFCII?
I think you have a stock ECU. In fact, post a pic of your motor... I have another suspicion.
01turbosentra
its def an an sr2odet trus me on that one its out of a pulsar gtir
nametakennow
You sure it's not a USDM SR20DE with a GTi-R turbo setup?
Anyway, pull the ECU out and look at the back of it. Check the numbers with a Nissan dealer.
RED_DET
Vendor
2011 Infiniti G37x
Just give me the numbers off the ECU and I will tell you what it is out of. If you truely have a GTiR setup, that is the first problem. They are hard to get tuned properly, especially if one isn't using the correct ECU. I would also like to see a pic of the engine bay.
01turbosentra
ok when at WOT the trottle position say im at 69.4 to 70.0 percent i dont think this is correct shouldnt it be at 100% and at closed trottle its at 00.4%
nametakennow
Wait, you said you had a Bluebird swap earlier, now we're talking GTi-R... this is definitely confused.
If you're talking about only showing 70% throttle on an SAFC, check your connections to your ECU wiring. If it's not soldered, I'd suggest that method.
RED_DET
Vendor
2011 Infiniti G37x
Until you tell me exactly what kind of ECU is running the car, its pointless to try and trouble shoot anything. So what are the numbers on the ECU.
01turbosentra
im confused to its a bluebird swap ok the pcm is jim wolf reprogramed pcm from a 95-96 ser mt 8.5 cr eser6-tmu03
nametakennow
Assuming you're still using the B15 harness, check the wires against this guide: http://jgycustoms.com/b14wiring.htm
By the way, punctuation would be helpful.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
