brokencar »
https://forums.nicoclub.com/brokencar-u271312.html
Sun Jan 22, 2017 5:03 am
Hi everyone.
The car in question is a 1985 non-turbo 300ZX with 120,000km. Auto.
Bought it and it ran fine for maybe 20-30km worth of short trips to get it registered and once that was done it started being a right pig to start of a morning - cranking for ages and the idle would fluctuate madly once it did start. After a day or two of that it started stalling as you pulled up at stop lights.
Pulled the IACV and cleaned it with throttle body cleaner - was plenty of carbonisation - unscrewed the little grub screw over the spring, cleaned all that and put it back in. Checked for vacuum leaks by spraying starting fluid around the lines, no change in RPM when the car was running.
The car went well after that evening for a test drive - no stalling. Turning on accessories (e.g. aircon, lights) sometimes resulted in the idle RPM increasing, other times it did not. Idle sat at 1,000rpm or so. Next morning back to the madly fluctuating idle (200-700rpm) and stalling at stop lights.
Above idle it pulls well and is responsive but it bogs slightly when initially accelerating out of the fluctuating idle.
Am I right in thinking that the IACV is stuffed? Anything else I'm missing here?
