Stalling when I hit the gas?
snowyred180
Car: 1994 Nissan 300zx TT, 1995 Acura Integra GS-R, 1994 Honda Prelude
It's that time again... time for another idle/stalling thread.
This time it's a bit diffrent. Today I started my car after driving it for about 5 minutes to the bank. It idled a little bit lower than normal. I let off the clutch, hit the gas, and it stalled. I started it again in neutrel, tapped the gas a little, and it started to stall. This time the idle was normal. Then I turned it off, waited like 1 minute, and it started up and ran fine. Drove home with no problems. The other day something simular happened. I was getting on the freeway, and under acceleration the engine lost power and stalled. Started it up again and it ran fine.
I know it's not something chaotic, probably like a vacuum leak or sensor (I'm thinking the coolant temp. sensor may be the issue), but has anyone had this happen or have any suggestions? I might try bleeding the cooling system since I had a leaky radiator hose at one point. That was fixed as soon as it started leaking and it nevr overheated; it may have let air in the system though.
Also, when the car is cold the idle seems to fluxuate a lot. It idles smoothly, just the idle speed goes up and down. I've searched, and searched, and searched some more and most of the other stalling problems seem different than mine. Car is a 1991 240sx with an SR20DET swap. It's only done this twice, and I've driven several hundred miles since the first time this happened with no problems. It's not holding me back now, but I want this taken care of before something serious happens!
nismoracingsx
Car: 1993 White 240sx Coupe
lookup your fsm and test the maf sensor.
corey170
Car: 91 240sx 5spd KA24DE h/b (current)
89 240sx A/T 2.4L (old)
I had the same problem, but i got an 89 with the ka24 in it.
got a really dirty cooling system (rust from the rad) and brown gunk built up on the coolant temp sensor (on top of the engine for the ka). I replaced that and it solved the problem, cheap and easy.
