Fla240sx »
https://forums.nicoclub.com/fla240sx-u71754.html
Thu Aug 23, 2007 2:47 pm
I have a similar problem kinda.......
I got a code 21 from when I scanned the computer, which translates to a bad ignition signal the scanner says... the Nissan FSM relates this to a code set when the engine dies under acceleration.........
the diagnostic charts start with checking the timing, then checking the ohms on the spark plug wires, then starting to check the mixture... starts with, what I guess is the o2 sensor... it calls it a wierd name... if all that checks out normal it says to check out the Crank sensor and MAF.......
so I'll be running through these diagnostic charts myself and see what happens........
so many people say check all this **** out whenever u have a stumble or bog... and so many people change SOOO many parts and nother every happens....
me I'm gonna go with what the computer and Nissan say........
