extreme135 »
https://forums.nicoclub.com/extreme135-u47620.html
Sun Apr 29, 2007 11:17 am
If you are running the sidefeed injectors, where are you saying it is loose at, you should see it leaking where it goes into the fuel rail, unless you mean that it is leaking around the o-rings, which is very possible if you do not grease up the o-rings when installing them and make sure that you tightened the two screws on top a little bit at a time and evenly, but I had a leaky one a time ago after doing all of that, what I did was pulled the fuel rail off still connected to the fuel lines, vacuum does not have to be, put some rags or a towel with some paper bags or newspaper on top of them and put that underneath the fuel rail and injectors on the intake manifold, disconnect the lines to your distributor cap, turn the key over(not engine) just enough for the fuel pump to prime itself to the fuel rail, if there is any fuel under any of the injectors, then it is leaking, this can be either from the o-ring or the injector may be bad if it is shooting any gas out of the injector passage holes at bottom, found my problem twice by doing it this way, one time it was an o-ring and one time two bad injectors, also is your car smoking at all when it is idling, and have you checked or tryied adjusting your tps sensor, I have seen people before when puting there coupler on there intercooler piping where it meets the throttle body, when you put your t clamp you can very easily hit and move the tps out of place, which will mess up your idle, and also I just noticed in your pic that your maf sensor is too close to the turbo, it needs to be at least 12 inches away, when you rev your car and the turbo begins to spool and then you let off, the wheel on the turbo will send false readings to your maf which will the ecu will dump more fuel to componsate for which will make the engine stall or idle eratically.
