overboostn07 »
https://forums.nicoclub.com/overboostn07-u53610.html
Fri Jan 12, 2007 8:51 am
i know its not the tps sensor, its in good timing, wxcellent spark, smooth throttle response and revs to rev-limiter with no hesitation, just idles at 500-700, battery light comes on, makes a couple of clicking noises and dies "if i dont hit the throttle to keep it running" after a couple of pumps at the gas the idle will com to 900-1000 and is fine. it only tries to die when driving and then come to a stop sign or light and take the rpm's from wherever they are at to idle by putting the clutch is. now the stuck egr valve sound more like it, where is it located?
