Stalling Problems
deathkeeper
Recently I have been having intermitent stalling only when it is cool outside in the morning. My idle also fluctuates quite a bit only in the morning, even after it has come up to full operating temperature. I suspect the AIV, as when I changed the air filter there was a black spot on it right where the AIV air induction line was. Any other ideas as to what it could be? I have replaced my TPS sensor (yes I adjusted it), and changed the plug wires, cap, and rotor. There is no fluctuating when I wiggle any of the wires on the harness. I will check out the AIV, and ignition timing today after school.
Axel Grungy
Car: 2001 G20 5spd
check the coolant temperature sensor. the connection could be bad, and it causes the idle to go whacky.
deathkeeper
Well crap... now if I wiggle any of the front harness connectors, the engine almost dies. Guess I will be rewiring them this weekend. Should I just buy new harness connectors for most of the front sensors?
